Introduction to Python for R developers
March 2018 · 12 minute read
I am a long time R user and I like R a lot. Coding in RStudio is a breeze and most every problem already has an associated package with a solution on CRAN. Nevertheless, I wanted to learn Python as well, because I firmly believe, if you only have a hammer, then every problem looks like a nail. Setting up a Python development workflow for data science proved to be a bit more work than I originally anticipated and that is why I wanted to provide a quick start guide for experienced R developers who want to get up to speed in Python.
First I will dive into setting up your coding environment on Windows 10 (macOS and Linux have similar, easier setups, but at work our laptops are Windows only, so here we go …). Then I will quickly cover how to work with virtual environments, install packages, write your own Python package with unit tests, documentation, linting and how to debug your code. Since I like working with Docker a lot, I will also include some additional information on making your Python code work nicely with Docker.
Getting started - VS Code as Python IDE
There are lots of great Python development environments out there, but personally I am very much in love with Visual Studio Code. I like a lightweight editor that I can customize to my hearts content. Plus, VS Code is available for Windows, macOS and Linux and is completely free to use. So this post will focus on VS Code.
Prerequisites
Before we begin, you need to:
  1. Download and install Visual Studio Code
  2. Download and install Anaconda Python 3.6
  3. Install Microsoft’s Python extension
Feel free to choose a different Python distribution, but I would recommend using Anaconda Python on Windows. Anaconda comes with most of the packages you are going to need for scientific computing and you do not need to build packages from source (which can be a pain on Windows).
After you completed the steps above, create a file called hello_world.py with the following code:
print("hello world")
Press ctrl+shift+p and type Python: Run Python file in Terminal and press Enter. You should now see ‘hello world’ printed to the integrated terminal.
Working with virtual environments and installing packages
When you work on multiple projects sooner or later you will run into dependency issues:
Project A needs library XY version 1.1, but Project B needs library XY version 1.2 and there are lots of breaking changes between package versions. How can we fix this situation?
One way to resolve this kind of problem is to isolate project dependencies using virtual environments. A virtual environment specifies and isolates the Python interpreter you want to use for a given project and (depending on which virtual environment tool you use) most/all dependencies. As already mentioned before, we will focus on Continuum Analytics’ package and dependency management system conda that is part of Anaconda Python.
conda provides a couple of very nice benefits compared to other similar tools:
Note: If you use Anaconda Python, do not change the default terminal in VS Code to PowerShell. Anaconda cannot active environments properly using Powershell.
Before we start, here is a high-level overview of how to use virtual environments:
Let’s start by creating a virtual environment called myenv:
Creating environments & installing packages
Open an integrated terminal in VS Code and type
# create the environment
conda create --name myenv
# Active/deactivate the environment
activate myenv
deactivate myenv
# create environment with specific Python & package versions
conda create -n myenv python=x.y
conda install -n myenv pip scipy=a.b.c numpy matplotlib
Note: You have to use source activate myenv on macOS/Linux.
It is also possible to use pip to install packages in a conda environment:
# first install pip using conda
conda install pip -y
# then use pip to install scipy
pip install scipy
You can select an existing environment by pressing ctrl+shift+p and typing ‘Python: Select Interpreter’ or clicking on the interpreter icon currently active on the right side of VS Code’s menu bar at the bottom.
You can also specify a default package list that is installed every time you create a new environment. Furthermore, it is possible to clone existing environments using:
conda create --name myclone --clone myenv
Information about environments
Use
conda info --envs
to get a list of all environments available.
You can easily see which environment is currently active by looking at your terminal.
(myenv) C:\your-working-directory
The active environment is shown in (). Alternatively, you can see an asterisk * in front of the active environment if you use conda info --envs.
To see which packages are currently installed in an environment run:
# to get a list of all packages
conda list -n myenv
# to check for a specific package (returns nothing or package version)
conda list -n myenv pip
Exporting an environment
An environment can be exported using:
# writes a conda config to your current working directory
# that can handle both pip and conda packages
conda env export > file_name.yml
# Build environment based on file_name.yml:
# to create an environment from scratch
conda env create -f file_name.yml
# to build an environment based on a .yml config run in an existing environment
conda env update --file file_name.yml
Deleting an environment
If you want to delete an environment and all associated content run:
conda remove --name myenv --all
Note: Don’t forget, if you use a Linux based Docker image you have to run source activate myenv!
You can also use conda to save environment variables.
More detailed information is available on the conda help pages.
Conda environments in Docker
Creating Docker containers with pip install is super easy. All you need to do is specify a ‘requirements.txt’ file for pip to use in your Dockerfile:
COPY requirements.txt ./requirements.txt
RUN pip install -r requirements.txt
However, conda always creates a virtual environment if you want to restore an ‘environment.yml’ file. So you have three options:
  1. Use conda install in your Dockerfile and specify all dependencies there
  2. Use pip freeze > requirements.txt if everything can be installed using pip
  3. Use conda inside your Docker container to setup a virtual environment in which to install the packages specified in your ‘environment.yml’ and either do:
Option 3.1 which I found on Docker and conda (shortened and modified):
FROM continuumio/miniconda3:latest
WORKDIR /app
COPY . /app/
COPY environment.yml /app/environment.yml
## create conda environment from environment.yml
RUN conda env create -n myapp -f environment.yml
## activate the myapp environment
ENV PATH /opt/conda/envs/myapp/bin:$PATH
Alternatively, you can try:
Option 3.2 from Using Docker with Conda Environments a bit shortened and modified:
WORKDIR /app
COPY . /app/
## Using bash! conda does NOT support sh, which is the Docker default (/bin/sh)!
ENTRYPOINT [ “/bin/bash”, “-c” ]
CMD [ “source activate your-environment && exec python application.py” ]
From module to package
Coming from an R background, I was a bit confused at first: People were sometimes talking about Python modules and at other times about Python packages. I was never quite sure if the two are merely synonyms or actually different concepts and if so, how they are different and how they relate to R’s concept of source files and packages.
Python module
Turns out, Python modules are basically equivalent to plain R files, but they get imported into their own isolated namespace. So in essence, a module is sort of an ‘R-package-light’.
Comparison: R file - Python module
R Python
Code source file.R file.py
Name source file module
Import command source(file.R) import file
Scope Global Environment (default) module environment
Every .py file can be used as a module, although some naming restrictions apply (e.g. don’t use a dot (.) or a question mark (?) in the filename, because they interfere with how Python searches for modules).
There are a couple of ways you can emulate this behavior in R. You can source(), i.e. import, files into their own environment or use packages such as modules or import. Still, I really like that in Python this is the default behavior to import additional code.
Module search path
When you use import to load a Python file as a module, Python will start looking in the directory of the caller (i.e. where your Python process was started) and then will recursively work its way up through the Python search path.
To take a look at the current search path run:
import sys
sys.path
When you use conda, it modifies this search path for you.
Package search paths in R work more or less the same way. R always starts by looking for a Rprofile.site file located in the R install directory. Afterwards, it will search for .Rprofile files in the directory of the caller and if it does not find one, in the user’s home directory and runs it. If either Rprofile.site or .Rprofile modify the search path, the new search path is used. Otherwise, R defaults to the user library and then to the system library.
To take a look at R’s current search path or to modify it run:
# print current search path to console:
.libPaths()
# modify search path for current session:
.libPaths = .libPaths(c("some/path/here", .libPaths()))
Or automatically alter your search path on R startup by putting the following in your Rprofile:
.First = function() {
    print("loading .Rprofile")
    ## Append custom library folder to libPath
    .libPaths(c("/usr/r_libs", .libPaths()))
Note: If you use RStudio’s build tools, you have to place your .Rprofile in the directory containing your RStudio project.
Python package
R enforces a pretty strict structure on any package. Python on the other hand considers any directory containing an __init__.py file a Python package.
Suppose you have a folder called foo that contains __init__.py, bar.py and some_other_module.py. Module bar.py contains a function print_bar():
foo/
    __init__.py
    bar.py
        print_bar()
You can import module bar from package foo using:
## importing using full name
import foo.bar
# or
from foo import bar
## specify a shorter namespace
import foo.bar as fb
# or
from foo import bar as fb
## import everything into global namespace
from foo import *
Python will search for your package and execute __init__.py. Afterwards, it will search for bar and import it into the foo.bar namespace.
Comparison: R package - Python package
R Python
Name package package
Structure R script + man folder, DESCRIPTION and NAMESPACE files multiple .py files in a folder with __init__.py file in project root
Import command library(package) or package::function() import package / import package as pkg
Scope package environment package environment
Exporting/importing in Python
If you have developed an R package before, you will remember that a user can always access all objects using :::, but you can specify which objects you want to be available to the user by exporting them, so the user can access them by calling library() or ::.
In Python you can specify which modules/objects of your package to export in your __init__.py:
__init__.py:
# 1
    ## expose modules for: from foo import *
    __all__ = ["bar", "some_other_module"]
#2
    ## expose modules for users:
    from foo import bar
#3
    ## expose objects for users:
    from foo.bar import print_bar
    # or shorter:
    from .bar import print_bar
Let’s take a closer look at those three import options in __init__.py:
  1. __all__ specifies which modules are available if the user runs from foo import *
  2. Using this option, the user can write foo.bar.print_bar() after running import foo.
  3. Now the user can access our function using foo.print_bar()
While you can import all objects of a Python package into the global namespace using from package import * (the equivalent of library(package) in R) this is considered bad practice and the following methods are preferable:
  1. import package as pkg or import package
  2. from package import specific-object-1, specific-object-2
I really like that you can shorten package names using import as in Python. The default way in R to achieve this functionality is to use package::function, which can be quite verbose (although you can do function <- package::function or use e.g. the import package).
Reloading modules/packages
If you changed parts of your package and you want to see the changes in your Python console you can either start a new Python session and import your package again or reload it. Reloading modules and packages works differently depending on your Python version. From Python 3.4+ you can use:
from importlib import reload
<some code here>
## Now you made some changes to the package foo.bar and want to reload it
reload(fb)
This is equivalent to using devtools::load_all() or building and installing the package again in R.
Documenting your project
‘The Hitchhiker’s Guide to Python’ recommends to always include the following files in your project’s root directory:
In R I use Roxygen, which is based on Doxygen, to document my code. While you can use Doxygen for Python, the recommended tool by the Hitchhiker’s Guide is Sphinx. Sphinx can convert reStructured text markup to HTML, LaTex and other formats (so it is equivalent to Pandoc in a way). Sphinx docs can be hosted for free on Read The Docs and rebuilding your documentation can be triggered automatically every time you commit to your repository.
In Python you use docstrings to document functions, modules and classes:
# leading comment block = programmer's note
def print_bar(string1: str, string2: str) -> str:
    print 2 strings to console
    This function uses PEP 484 type annotations and
    prints two strings to the console.
    Args:
        string1: some text to print
        string2: some more text to print
    Returns:
        Prints string1 and string2 to the console
    >>> print_bar(1,2)
    '1 2'
    return print(string1, string2)
Using tools such as Doctest allow you to embed unit tests in your docstring (prefixed with “>>>”, see above).
Docstrings can be accessed by using the help() function.
I hope you found this little guide useful:)
